ajayre
I have 12mm plywood and I need to create a lot of 25mm holes in it. For previous parts like this I used a hand-held drill and a Forstner bit, but it is slow going. I have to cool down the bit regularly and I have to drill each hole from both sides to avoid splitting the veneer. It's hard on the drill batteries which I have to keep swapping.
Is there a better way to quickly and easily create these holes?
My only thought is a template with a plunge router and a a spiral bit, but it will be tedious repeately clamping and removing the template.
Thanks, Andy
Thanks, Andy
