thetyreman":19p82um2 said:
I would definitely go with breadboard ends as well, but proper breadboard ends are not a walk in the park for a beginner, they are at least intermediate level possibly advanced level, you'd have to practise some joinery first and be good at mortise and tenons and drilling precise holes for the pins, some people think they're ugly but I see them as a sign of quality and it's going to be an heirloom piece not just another throw away table if you do it properly.
hmm, not REALLY "intermediate level possibly advanced" - I've done it a few times inc on the tabletop previously mentioned - routed out the mortice (and not even with a fancy router table either), chopping the tenons is just a matter of patience and a sholder plane. Marking the position of the pins first drilling through with a small 3mm bit, then offsetting the tenon hole by a smidge so it draws on the breadbaord end for a tight fit.
If I can do it with my inadequately tooled "workshop" - anyone else can in a similar situation.
You can even simply it and not do M&T's and just cut a long tenon for the board ends (just router down the thickness both sides by an equal amount) then slot cut the breadboard end to suit.
I've done it both ways and the latter seems simpler, but really you have to be just as careful fitting the tenon in a slot as opposed to a mortice, by routering it a little "fat" and paring down as normal.
Pins go in the centre of each table board for minimal lateral movement.
Plenty of vids on the subject to watch.
