First impressions, well packaged, the handles are wood and although finished? are dull in appearance compared to the stock photos,
After cleaning the plane to remove the oil coating ( just wiped with a rag at this stage), it is a clean casting and nicely finished ( didn't pay too much attention to the paint finish), it has a good weight but not too heavy to use for any length of time.
So down to business, straight from the box adjusted the blade and started on some softwood ( no hardwood to hand at the moment), and took shavings immediately,
so far so good, took shavings of various thickness, and was able to get one just about fine enough to see through( bear in mind this is without any honing and straight from the grinding angle)
The sole would be within tolerance for a new tool( assuming here)
and across the width
The front handle ( on the no4 mainly) had reports of the screw being proud on the top, this seems to have been resolved
and now sits just below the top,
There is also frog adjustment
Also what i find a nice touch is the grinding/sharpening angle engraved on the chip breaker
So until further testing once it has been fettled, for a budget plane to perform from the box without any treatment i would say it has the potential to be a fine tool, and i would say it would need very little fettling to be able to compete with the bigger branded names.
