Hello there,
I have recently made and fitted a gothic-headed hardwood door and frame. They were fitted nicely (so far as I can remember), but now, six months later, the door has warped quite considerably (approx 5/8" across the full height), and the client is angry as ****.
Usually I would say this is down to bad luck and the fact it's a wooden door, and do my best to make it work for the client, either by replacing the door, or by putting the door under various kinds of pressure in the shop. However in this particular instance I think there is quite a strong case to say that the client is to blame, for one main reason: they insisted that the door frames and doors needed to be fitted *just* before a screed floor was laid across the entire ground floor (>100m2), so that the screed could run up to the bottom of the frames. I wonder whether the excess humidity in the screed floor could have contributed to warping the door.
Has anyone else has come across this problem? And if so, do you have any advice (legal or otherwise) on who might be liable in this instance? Would be really great to hear your thoughts.
Many thanks in advance!
