Excellent video on bandsaw set up with Alex Snodgrass
A wise man once told me it is always important to know "why" you're doing something before you invest too much energy insisting it's the right way to do it.
Perhaps a watching of this will make clear the governing principles behind the "why" crowned pulleys work and therefore the reason they're designed like that. That knowledge can then be fed into the thinking of whether or not it's a good idea to track blades according to Mr Snodgrass's principles, or the alternative which is what the manufacturers say, which is more or less central to the tyre. To me, it's pretty obvious I have to say.
Here's the piece:
http://woodgears.ca/bandsaw/crowned_pulleys.html
Having laid out all the facts like that, I still agree that if Snodgrass's method is working for someone then I'd stick with it on the what the heck if it aint broke don't fix it principle. But just know why...that's really all I'm on about with this.....no dogma......just some intel in case one day it doesn't work, perhaps with a different sized blade and people get confused.
Alex Snodgrass, of Carter Induistries has an excellent video on a set up method that works very well and I use his method as I generally use smaller blades, from 1/8" to 1/2". I have not tried a 1" blade, but that may be more difficult to locate the tooth gullet in the centre.
When I first started using a bandsaw, I watched dozens of videos on how to set up and tweak for best performance, but Alex's method was a change from what I originally thought and it works well, particularly when using the Carter Stabilizer for the 1/8" blades I have from TuffSaw, but I do still centralise the teeth when using the normal guides.
However, for anyone starting out, then the Steve Maskery DVD's will show you far more about how best to use the machine once set up and they are a real investment. http://www.workshopessentials.com/shop/
Alex
