Evolution R255TBLX+ Table Saw
Jobe1972
9 Feb 2025
coventry
Hi I have never had a table saw before never had the space so I just bought this one R255TBLX+ Table Saw from evolution have a few of there tools always been great but I seem to have a few issues with this saw main one being movement from side to side on the blade. just need opinions if it should move that much to me it shouldn't but like I said never owned one before
  • 8f146e01-a172-4024-83a7-70f4cfec73bb (1).mp4
    3.6 MB
No. it shouldn't move at all in that way. It looks like the arbour itself is loose, not just the blade on the arbour. It would be dangerous to use that as it is.
Agreed on the arbour issue - is the nut tight? Out of interest you say it's the X version - I thought that was 110v model (i.e. runs off a site transformer)
I've only just started to use my R255TBL+ but so far it's excellent.
This is off the invoice R255TBLX+ Table Saw 220V-240V/50Hz UK I had already emailed evolution they asked for a video and the one posted here is what i have sent them just waiting for a reply
I struggled to undo the nut to check it was seated correctly it was that tight.. I took off the blade etc and put it all back making sure it was seated as it should be and the video is the result exactly the same as before I took it off
Are you using a reducing washer? If it is thicker than the blade material it will not tighten on the blade properly and may give a wobbly effect? Just a thought..
Not using anything This is exactly how it came out the box I didn't even need to add the blade as it was already installed so I did nothing when It first came accept build the stand
