thetyreman
no7, no5 1/2, no 4 1/2 are my most used planes, I like the wider planes more, even on narrow or small stock, it just feels more solid, plus I have huge hands which can be annoying.
"A scrub plane is designed to quickly remove large quantities of wood. Based on the Stanley 40 1/2, the open throat and curved blade allow you to take deep cuts with ease"D_W":ecwwv9xb said:According to Lie Nielsen, the scrub plane was designed to do things like make doors narrower.
Tasky":2thfb9ec said:"A scrub plane is designed to quickly remove large quantities of wood. Based on the Stanley 40 1/2, the open throat and curved blade allow you to take deep cuts with ease"D_W":2thfb9ec said:According to Lie Nielsen, the scrub plane was designed to do things like make doors narrower.
"In the past, Scrub Planes were used like a Thickness Planer to take rough-sawn boards down to size. Then the woodworker would progress to a Jack Plane, and finally to a Smoothing Plane"
https://www.lie-nielsen.com/product/scrub-plane
So yes, narrowing doors might fit in there, but mostly hogging off great thicknesses of wood.
And since I don't have space or money for a thicknessing machine....
Last two paragraphs of particular interest:
https://www.popularwoodworking.com/wood ... ous-animal
Strange.D_W":wpr2mtoo said:Tasky":wpr2mtoo said:"A scrub plane is designed to quickly remove large quantities of wood. Based on the Stanley 40 1/2, the open throat and curved blade allow you to take deep cuts with ease"D_W":wpr2mtoo said:According to Lie Nielsen, the scrub plane was designed to do things like make doors narrower.
Lie Nielsen's text is wrong. They've said elsewhere (perhaps in video - it was the SIC there who made the comment - deneb) that it is a tool intended to do exactly what Stanley says - reduce the width of boards, and not thickness.
A jack plane is far better (and at least as fast - and faster once the follow-on work is considered) than a scrub plane for thicknessing lumber.
To someone fitting doors, if the amount needing removal was something like a quarter of an inch, there in between planing and sawing, and then the plane makes sense. As to anyone doing any significant dimensioning, abandonment of a scrub plane for a well-made and well-set jack plane happens pretty quickly. We try not to get stuck doing things like planing a half inch off of a five square foot board, and high spots are easily removed with a jack in such a way that garish tearout and torn off edges aren't a problem (like they are with a scrub). It's an impractical plane for general shop use, but the concept seems attractive. If it was practical, it would've existed long before the 1890s, but by then, Stanley was probably focusing on site work professionals. The market of mail order millwork, etc, was well established here, and that work wasn't being done by hand, but fitting mail order and factory made millwork certainly was.
Interesting info. I see there is an article from Chris Schwarz on the pop woodworking site about the scrub plane (from about 2005) basically making the same point about it historically. Reckons it was more of a site carpenter's tool.D_W":2e4bxiv8 said:It's not that you *can't* do it, it's that it's not historically accurate. Usually when something isn't historically accurate, you find out why when you get more experience (in this case, because a jack plane is better for the job. ).
You'll find youtube videos of all kinds of things. Like guys making double iron planes. You can never believe them!!
(in this case, though, follow historical practice if you want to prepare rough lumber by hand - you'll be better off and you'll have fewer fits with gross tearout and blown out edges of boards, and spend less time and effort in the process).
When I started to do some of my work with only hand tools, I found it pretty difficult to locate other people who actually did the same thing. Suggestions of how to dimension wood from people who generally run their boards through a thickness planer are plentiful. I can say that the advice that I've gotten from Warren Mickley has been accurate every single time. I traveled my own path through several dozen planes to end up with a wooden jack, a wooden try plane (and a metal jointer for some cases where the work is rough on a try plane), and a metal smoother.
Warren works by hand in the middle of PA where amish (who don't do much hand work) makers are plentiful and makes his living doing jobs that are cheaper to do by hand than with machines (restoration, carving, sash work, etc).
I'd imagine most of the people showing dimensioning work in videos and using a scrub plane, etc, or a lot of modern boutique tools - probably don't do much of it when the camera isn't on.
Chris Schwarz writes a lot about hand tools (the above article is a bad example, because it's from 12+ years ago, and he's comparing thicknessing a board with a scrub plane as being "fun" vs. a smoothing plane. It's completely irrelevant), but he also often writes narratives that suggest he's not very good at completing rough work with them (e.g., talking about being unable to cut the end off of his bench with a hand saw and going to a circular saw to complete the task - I don't think Sellers did that on his bench videos, but I'll admit I'm chancing that because I haven't actually watched it. But I can watch sellers and see that he is a competent sawyer). His demonstration of sawing on Roy Underhill's show was pretty painful whereas Marcus Hansen's demonstration on the same show was a display of control and experience.
I merely looked up what you said and that's what I found....D_W":2pg54r0c said:Lie Nielsen's text is wrong.
Apparently it did.D_W":2pg54r0c said:If it was practical, it would've existed long before the 1890s
Oh, yeah, that'll be Sellers, Schwarz, Charlesworth, Maguire, Cosman, Wright, Wearing, Tribe and all the other Woodworking Gurus lying to you to sell tools, innit.... I'd just assume anyone you've heard of is a complete liar now, just to be safe, y'know? :roll:Bodgers":2pg54r0c said:If that's the case why am I seeing youtube videos with people reducing boards down to thickness and leveling using scrub planes? Is this the Internet misinformation at work again?
Sideways":2da6kplk said:Related to the original question - do any experienced woodworkers use two of any plane ?
I've inherited my Dad's tools with leaves me with two identical Record #4 smoothers. Trying to decide if the "spare" one is better traded along for something I don't have or maybe setup with a cambered iron and an open mouth and kept for scrub planing.
I find the tote of the Record #4 uncomfortably small so I need to rehandle at least one of them and try a 4 1/2 before I make a decison.
Silly_Billy":3itx0dhp said:I can see that if I ask two experienced woodworkers for advice, then I’ll get three answers![]()
D_W":3h7cgwen said:Well, if they're both accomplished, you might get very similar answers. If you ask a guy who writes books, and then ask a guy who fed himself doing the work the guy who writes books wrote about, then you might get two different answers. I'd probably rely on the answer from the guy who does the work, and save questions about how to write or publish books for the writer.
D_W":1zb9v6n3 said:Scrub planes have geometric characteristics that make them expert at surprise catastrophic tearout, and chunking the ends and edges of boards.
I'm happy using 400, 1000 and 8000 stones, together with a leather strop. I don't feel sharpening is holding me back, thanks to taking a sharpening course. However, I won't claim to be Ron Hock and am hungry for any woodwork tips.D_W":2z7ppsuq said:Aside - I think you should start a question about the least number of stones that you can use to get an acceptably sharp edge, or the lowest possible cost for a reasonable sharpening system and what it is.
Well, I'm finding Christopher Schwarz's book helpful. Similarly, I bought a David Charlesworth DVD (recommended on this forum) that I'm finding extremely helpful too.D_W":2z7ppsuq said:I'd probably ... save questions about how to write or publish books for the writer.
That's good. Unfortunately, I can't tell who's accomplished via an internet forum! For all I know, D_W, you could be the Theresa May masquerading as an accomplished woodworkerD_W":2z7ppsuq said:Well, if they're both accomplished, you might get very similar answers.
Interesting. I assume you mean the German wood planes like ECE, Ulmia etc? I always assumed they were basically the same. I.e. smaller width sole, wide mouth, cambered blade.patrickjchase":7go4gbvy said:D_W":7go4gbvy said:Their use of the term "fore" to describe a panel plane was a particularly egregious example, but the Stanley #40 isn't quite the same thing as a Continental scrub either.
Silly_Billy":jlr8nx2r said:via an internet forum! For all I know, D_W, you could be the Theresa May masquerading as an accomplished woodworker![]()
