Erm... First outing with Pocket Hole joinery...
matt
4 Sep 2005
Miles away - totally impractical...
It was late...
Kinda didn't think... :?
But the good news is that it's going to be painted...
:lol: :lol: :lol: :lol: :lol:
(The face frame is not fixed to the cabinet yet)
I presume youve pocket screwed the wrong side. :( You can get wooden plugs to fit the pocket holes which will probably shrink less than filler and be less noticeable under the paint.
jon
Of course you did it on purpose to see if anyone was paying attention :lol:
I make my own plugs 9mm dowel angle hole in a block of wood clamp it in chop saw insert dowel cut done easy
Matt
drill a hole in a piece of scrap hardwood using your pocket hole jig this gives you the right angle for the plug
I glued the angled hole timber to the end of a batten to allow for clamping in your mitre saw.
then clamp assembly in mitre saw with blade just brushing the edge of the hole .
put dowel in angled hole and cut one angled plug cut dowel to length 2nd angled plug.
hope this helps
