Wend
Finally got this finished!
It translates between braille, morse code, semaphore and binary.
Probably the hardest and most time consuming part was just getting all the wood planed flat and square. Here's the top with the hole layout punched.
116 7mm holes for the LEDs and buttons on the top (fortunately both wanted the same size, which eliminates a whole lot of potential mistakes. Still pretty nerve wracking knowing that one hole in the wrong place takes me back to square one)...
...with the backs widened with a forstner bit to accommodate the components.
Some pyrography finishes off the top.
Sides dovetailed together. They're currently far too tall, as I wasn't sure how tall I needed so I just made sure to overshoot.
Some components are very close to the edge, so needed some space chiselled out for them to fit into.
Finally, just wire it all up!
Finally, glue the top to the sides. I only put glue on about an inch on the short sides, so the top is free to shrink or expand; hopefully those couple of inches will be enough to hold it together!
Many thanks everyone for all the advice over the last year and more; I'm sure I wouldn't have got there without you!
