Trextr7monkey
Hi I acquired a lathe with a VFD wired direct to the single phase motor which works fine. It completely by passes the original switch gear so I thought I could fit a mushroom head emergency stop in place of original switch but I’d read that running VFD with no load could damage it so I would like to check that the emergency stop should be fitted upstream of the VFD so that it stops everything. I don’t really want to get into lots of complications and disturb some thing that works fine at the moment but would very much welcome advice on this
Pics show original switch which was on off and reverse and the VFD in question
