devonwoody
The wife needs a larger pin box to replace her plastic freebie she has had many years.
So my first attempt at a glue up a couple of days ago failed because of low temperatures, so this time its back to the kitchen for the glue ups.
I'm wanting to make this a lightweight box so reducing side thicknesses down to around 4mm and less at a later time when box has been made.
So used double sided carpet tape on some MDF and had no trouble getting Br. Mahog. down to 4mm.
Then I cut into 35mm strips on the tablesaw using a 60t blade.
Prepared a former from some 4x2" covered with cling film and glued up the strips on to a thick base (for now)
Took into kitchen to set glue.
When the glue had set I had trouble getting the box off the former, so I put in some 2" screws.
Got the former out by clamping the screws in the vice and dragging off.
Brought box base back into kitchen for next 24 hours and then will do a clean up.
Will start to prepare for the lid next and at the same time I am struggling to prepare timber for the next project a chevron box.
