I've just begun refreshing my hand-operated drill press.
Having stripped the paint with paint stripper, removed the rust with Jenolite, wire brush and emery paper, washed down with water, tidied up some more with emery, cleaned with acetone and rags (twice) and cleaned with dry paper... (A pretty thorough pre-painting clean I figured)
On applying etch primer I've had a skim of oil start migrating into the paint leaving dirty marks and crazing.
I'm waiting to see what happens when it dries, to call whether the paint has adhered well and can be saved with a good sanding before undercoating, but assuming I will have to strip and repeat the whole process.
Anyway, the nub of the question is how could I have predicted this before painting (given the parts appeared to be spotlessly clean), and if I do strip it and repeat, what the best way to prevent this happening again.
All advice gratefully received.
