jkljosh
Hello Guys and Gals
I thought I'd try to post my first WIP, albeit just as I'm completing the project!
I had a fairly open brief from a client to design and make a dining table to seat 8. They wanted something "interesting" to sit centre stage in their large garden room adjacent to their open plan kitchen, replacing a worn traditional style large pine job that they’d had since getting married. The only thing they were adamant about was the need for a “substantial” top. Lots of sketching and a 1/10th scale macquette later we settled upon the idea of “slabby” legs and gently curved top.
Typically the lovely straight grained elm log that I’d seen at Prime Timber in Fareham early in the design process had sold by the time the design was finalised. However, seeing my disappointment Andy mentioned that he had a nice section of burr elm from the Holyrood Estate in Scotland, that might fit the bill. I wasn’t convinced that I could risk such a radical departure from the broadly agreed design, however a phone call to the client generated a very generous response – “we’ll go with what you think best”! No pressure then as I handed over the ££ for the complete air dried (2.5yrs) 8.5 ft burr elm log. It was just over 2ft in diameter at it's widest and converted through and through into 8 x 2.25" boards. The figure, even in the rough sawn timber looked incredible.
I needed to get the MC down, so had the whole log cluttering up my heated workshop for the best part of 6 months.
In the absence of a moisture meter, I decided to weigh the boards on a regular basis until their weight stabilised – I’m not sure how valid that is as an approach, but it seemed better to do that than start working “wet” boards. Eventually they seemed to settle around 45-50kg a board and so it was time to start work in anger.
Originally I had intended to create the top in reasonably conventional style – cutting the boards down to a size that would fit through my planer/thicknesser. However the figure in the log was so spectacular I decided that it needed to be made into a feature by book matching adjacent boards, for both the top and the legs, while using the waney edge to provide interest for the edge of the table. The only problem with doing so was that it left me tricky challenge of flattening/thicknessing 24” wide boards. I’d seen an article in FWW about flattening large slabs using a router and sledge arrangement and so set about some 18mm ply to make the jig. If I was to achieve anything close to two parallel and flat surfaces I also had to make up accurate support beams and rails on which to run the sledge. It was only once I sat down and thought about it, that I realised that the size of the set up needed (to make a 7.5ft x 3.5ft tabletop) was going to be a real challenge in my small workshop.
Many passes of a Wealden 3 wing surface trimming bit and several bags of router shavings later I had 4 reasonably flat and parallel planks to play with!
More to follow including - the joys of hand planning/scraping wild grain table tops, donkeys ears and wobbly edges, preparing the edge joint using Veritas' bevel up jointer, manufacturing brass fitments, and most exciting of all - the miraculous reveal when I first applied oil to the top.........
P1010214 (Medium).JPG119.2 KB
P1010142 (Medium).JPG176.1 KB
P1010140 (Medium).JPG191.6 KB
P1010144 (Medium).JPG162.9 KB
P1010158 (Medium).JPG184.7 KB
P1010148 (Medium).JPG182.3 KB
P1010146 (Medium).JPG215.4 KB
P1010147 (Medium).JPG234.3 KB
P1010160 (Medium).JPG187.5 KB
