CYC
After a long search for the right table saw I have finally made a choice and blew my budget out for the Elektra Beckum PKF 255 V8.
I haven't started any project with it yet, but my first impressions are very very good. It feels solid and heavy resulting in no vibration when starting and using it. The sliding table is very smooth and the induction motor is like music to my hears 8). Setting the rip fence is easy and very accurate, you lock the front to the correct lenght and secure the back of the fence to ensure straightness and stability for your cut.
Raising and lowering the blade is also very smooth and accurate. Not to forget the scoring blade which can be raised/lowered from the table top. The 2 blades run independently, if you are not using the scoring blade it doesn't get switched on automatically with the main one.
I haven't got experience in writing a review but if anyone wants to hear about a particular feature of the saw I'll gladly go hands on and give a good report. Also I'll update this thread as I use the tool with real projects.
One aspect I found not so good: to access the blade and change it you need to remove the entire sliding table (which is very heavy). Once this is done you shift aside a cover panel which is held by clever hinges (nice touch) and can easily change the blade.
If someone knows how to do this without having to remove the sliding table I would love to hear it :idea:
CYC, enjoying every cut I make with this table saw :lol:
