carsey2006
New member
Hi all,
I hope ive chose the correct forum section for my issue i'm having.
We have a Elektra Beckum HC260M Planer/Thicknesser at home for some light wood work jobs. We went to use the P/T the other day and it keeps blowing the fuses. The motor/blade assembly will rotate roughly 10% of a turn and blow the fuse in the plug.
I had a google and realised this is a pretty common issue and either caused by the motor centrifugal switch sticking open or the start/run capacitors have aged.
The capacitors in ours show no signs of any damage/bulging or odd marks and look as new. (I guess the larger capacitor of the two is the initial starter cap and the smaller maintains the run demand on the motor?
I whipped the rear plastic casing off protecting the fan to try see the centrifugal switch but there is nothing to the rear or front of the motor I can see. The motor, belt and blade assembly turns over perfectly fine.
Unfortunately, my cheap Chinese multi-meter doesn't do capacitance, so I am unable to test the capacitors to ensure there is no dead shorts or they are out of the tolerances by the manufacturer.
Has anyone got one of these machines are are electrically minded to give me a bit help in order of what to try next, rather than just go out and buying 2 new capacitors and hoping it fixes the problem.
Thanks in advance
Chris
Thanks in advance
Chris
