Elektra beckum hc260 help
Aylest94
31 Aug 2021
Taunton
Hi all,
After some advice. I have just picked up and elektra beckum hc260 planer thicknesser. I can't seem to adjust the infeed table. I can twist the adjustment knob to a certain point but the table does not move. I can back the adjuster all the way out but the table itself does not allow to go in past a certain point. There is no movement in the table at all. It is a blue machine that says metabo on it if it's makes much difference. Any ideas before I take it apart?
Thanks in advance.
Tom
I'm afraid I do not have any real advice but I took my green HC260 infeed table off and got it back without any issues. It's a pretty simple assembly really. I'm sure you will be able to manage it if you have reasonable mechanical skills.
Good luck.
Martin
