Gary S
Morning all,
I've just had a 12 x 6 shed built in my garden - it's going to be storage for all the gardening stuff plus golf clubs, bikes etc, but also a bit of an overflow from the Workshop (a.k.a. Garage!). Just don't tell SWMBO... :wink:
I am going to put a workbench in there and use it for some of the smaller tools - sanding, drill press etc. I'll still use the garage for the bigger, noisier, messier stuff!
My question (yes, I will get there eventually...) is what electrics should I put into the shed? I was thinking of having quite a few power points (including at least one double socket in the ceiling which may be handy). What lighting would people best recommend - halogen type downlights or strip flourescent lighting or something else?
Also, do you think it would be worth fitting an extractor (such as the ones you have in a bathroom)? I may use the shed to store some of my seasoned timber - would an extractor help to keep a bit of airflow going or is it not the recommended thing to do?
I'm going to insulate the shed with polystyrene and then clad the walls so it would be good to get the electrics all sorted before I do that. Obviously everything will be check fully by a qualified electrician... :roll:
Any help / advice / experiences gratefully received!!
Gary
Gary
