Hello Paul;Mr_Grimsdale":2tubd79i said:No it's dead simple - if you don't know which one to use , use a jack.
If you get handy with a jack you hardly need any of the others - they're gilding the lily, adding value yes, but marginal.
cheers
Jacob
Radically improves performance if you stick a bit of 60 grit paper to the sole and put Fred Astaire on the sound system.Scrit":175j6h50 said:Sure they weren't klompen? (clogs) :roll:
engineer one":rvbr0ske said:interesting bench top too :roll:
paul :wink:
Hello Paul;engineer one":25ne9ddd said:i think the problem is that you are actually trying to learn two skills at once,
holding the plane flat and square in the vertical plane, plus pushing it along at a horizontal state.
i have used a modification of that idea, and gotten where i want i think,
but it does re-iterate my thoughts about going on a course :roll: paul :wink:
mr":25ne9ddd said:Paul on a single boards edge width you can also use your fingers as a fence which is what I do. The thumb sits on top of the plane, centrally and just in front of the blade and the rest of the fingers curve under the sole with the tips pushing against the workpiece. Like so
Cheers Mike[/img]
mr":3g2stvdh said:Paul on a single boards edge width you can also use your fingers as a fence which is what I do. The thumb sits on top of the plane, centrally and just in front of the blade and the rest of the fingers curve under the sole with the tips pushing against the workpiece.
