+1 for Jacob's post about rubbed joints. It will also work with liquid hide glue, which I find preferable for occasional use.
D_W":1avc36kh said:CStanford":1avc36kh said:Sadly, I no longer have the Planos. Can't recommend them highly enough though. Of course you still have to joint edges for them to work well. I used to have a hand-held RF wood welder too which made the Planos really make sense. Different business model, and all that.
Never saw an RF wood welder before, and I worked at Aristokraft in college! (I was in the mill and assembly area, though, and doors and face frames were done elsewhere, so I wouldn't have seen something like that there, anyway).
Kind of a nifty device for a small shop. If you had several similar panels, you could put them in the planos to line them up and zap them with the wood welder.
CStanford":hnkzm0lm said:I've never built a musical instrument in my life, and I'm sure that I never will, but I'm a little surprised to hear that stock would need to be glued into panels for instruments as small as ukuleles. I'm thinking I'd focus efforts on finding wider stock.
It's an option but most string instruments are book matched, top and bottom. Not so necessary with smaller ones of course, and single piece backs also feature on some top end instruments. There are all sorts of variations.CStanford":2erjvjhg said:I've never built a musical instrument in my life, and I'm sure that I never will, but I'm a little surprised to hear that stock would need to be glued into panels for instruments as small as ukuleles. I'm thinking I'd focus efforts on finding wider stock.
I don't really know but my feeling is that volume production models would use the quickest and easiest method which would be rubbed joint with hot glue. Top end would be different - clamping and fewer risks taken with expensive bits of wood!profchris":1f2332s5 said:I'm skeptical about Jacob's assertion that musical instrument tops and backs were joined with rubbed joints. The plates flex too much to get a decent alignment.
All the methods I know use some form of clamping, though not much if using HHG. For example, I join ukulele tops and backs simply by taping the plates together along the join to keep them aligned, "tenting" the joint by putting a pencil underneath, then tapping panel pins next to the outer edges into a flat board. Glue in joint, remove pencil, press down, weight on top to keep them flat. Spanish guitar making tradition tends to use a flat frame to hold the plates flat, and then string wrapped round with wedges inserted to pull them together.
The joint is fitted by eye, but again the tradition tends to use a shooting board, planing the plates back to back (or front to front) and then working away on the gaps. No-one I know clamps between sacrificial boards because you need to check the joint against the light after each plane pass, and that's a lot of unclamping and realignment. With a shooting board hand pressure is enough to hold the plates for planing.
Door panels I know nothing of, but they're rigid enough for a rubbed joint.
That's not to say musical instruments don't use rubbed joints - that is a good way of fitting the much more rigid bridge (for some, but not all, shapes of bridge), and this is the high tension joint in an instrument!
CStanford":9w9ey54g said:Hey Mike: kitchy Latin music, but still interesting:
https://www.youtube.com/watch?v=c-ZnaNyDbOo (wish I still had my D-J 20!)
... in for the day....
Violin top plates (and violas, cellos and basses) are made from Norwegian Spruce and are usually rub jointed but the sycamore bottom plate is clamped, I don't know the reason for the different approach, but imagine it must be to do with the hardness of the wood. The arching and thicknessing is done after the jointing so it is quite a solid piece of timber when jointed. These are glued with hot hide glue.profchris":3gkssjlr said:I'm skeptical about Jacob's assertion that musical instrument tops and backs were joined with rubbed joints. The plates flex too much to get a decent alignment.
I'm told that the sycamore bottom plates were rub jointed the same but with two goes at it - the first one being to fill the grain with glue and the second one to actually glue it.Paddy Roxburgh":2sa4oj4y said:Violin top plates (and violas, cellos and basses) are made from Norwegian Spruce and are usually rub jointed but the sycamore bottom plate is clamped, I don't know the reason for the different approach, but imagine it must be to do with the hardness of the wood. The arching and thicknessing is done after the jointing so it is quite a solid piece of timber when jointed. These are glued with hot hide glue.profchris":2sa4oj4y said:I'm skeptical about Jacob's assertion that musical instrument tops and backs were joined with rubbed joints. The plates flex too much to get a decent alignment.
Hide glue from a potJacob, when you say hot glue do mean hot hide glue from a pot or the stuff that comes out of a glue gun?
Actually I have planed up a lot of plates of various sizes from thick table tops to thin box sides. Your no7 trick sounds difficult. My method is to plane up the meeting edges as well as you can, hold one plate in the vice vertically and sit the other on it. It's then obvious how it fits or doesn't fit and I then plane accordingly. Check they line up flat with a short straight edge (combi square ruler), check they don't rock due to high points, check no visible gaps, etc. It's quite easy and has the big advantage that the pieces are not under any pressure and you can see both sides of the join.I have only jointed one pair of plates and was shown how to do it buy putting a no.7 in the vice and pushing the wood over the plane, aiming for a very slight hollow.
I am certainly no expert in this, (but the person teaching me was), so f there are any violin makers reading this who disagree I will bow (see what I did there) to your greater knowledge and experience.
Paddy
Paddy Roxburgh":4a7ojvhb said:Violin top plates (and violas, cellos and basses) are made from Norwegian Spruce and are usually rub jointed but the sycamore bottom plate is clamped, I don't know the reason for the different approach, but imagine it must be to do with the hardness of the wood. The arching and thicknessing is done after the jointing so it is quite a solid piece of timber when jointed. These are glued with hot hide glue.profchris":4a7ojvhb said:I'm skeptical about Jacob's assertion that musical instrument tops and backs were joined with rubbed joints. The plates flex too much to get a decent alignment.
Paddy
