DWE7485-GB Table saw blade advice
SCMG001
12 Mar 2020
Shrewton
Recently bought DWE7485-GB and really working well. I wanted to get a blade for cutting plywood finely, and (naively) purchased Dewalt 210mm x 30mm 60T FlexVolt Xtreme Runtime Saw Blade, thinking that this should be ok, as it is for the same saw, except battery operated. (mine is corded) . Fitting the blade, and then running it, I noticed it started slipping, an upon checking could see that it was unable to tighten any further against the blade , as the new blade is thinner than the original one supplied with the machine. Can this be, so little margin for adjustment to tighten?
Just wondering if anyone has had the same experience, would it be safe to add a washer? Alternatively what blade 40t + would you recommend that works well for a DWE7485-GB?
Many Thanks in advance
    11.3 KB
