gregmcateer
He's good that Mr Bob!!
sunnybob":38mw6hdc said:Nah, wont work.
All you've done is reduce the air flow in any one part by 50 per cent. At the furthest away point you will have pull from both sides cancelling each other out.
And every joint and connection also reduces the flow.
Work your ducting to have the minumum of joints and the absolute minimum of tubing.
Try to keep the blast gates as close as possible to the main pipe, other wise you will get "dead legs" where the air is just swirling rather than pulling.
sunnybob":2k0elor9 said:Just to clarify my last...
I'm assuming your work space is fairly small, single garage sized, or near.
I f you have a big workshop, then having to walk across the floor to change a blast gate everytime you want to use a different machine can become a real pain, so then you might want to put them as close as possible to each machine.
Machine layout is very important to help you keep pipe run to a minimum. If you use both sides of a small space them consider the pipe to run overhead along the centre, or even diagonal, to keep the run to each machine at a minimum.
I only have a 5 x 3 metre workshop, so I have 5 outlets on mine, but they are all along one wall, so my pipe run is barely 4 metres, with the blast gates all in one place as a kind of "command centre" thats only three steps from any machine.
