This is it...
Ok, it's not much use to anyone or thing, but it's a start. I had a go at one of the tutorial bits in Keith Rowley's excellent book. I rounded off a square length of pine with the roughing gouge and then formed these coves and beads with a 10mm spindle gouge. I then tried smoothing things off a bit with a round nose and square end scraper. The finish from the spindle gouge was actually pretty good but the curves weren't very symmetrical. The scrapers worked wonders on the symmetry but tore through the fibres a little and made the surface a little rough. I sanded off with only 120 grit paper (all I could find at the time).
I'm quite pleased with it and now I'm itching to try a goblet (and maybe even a bowl).
