I have very kindly been donated a lathe- an Arundle which I believe to be a J4.
http://www.lathes.co.uk/arundel/
I am completely new to turning, and before investing heavily in a chuck, I am going to get a few cheap tools, and turn some bits between centres. At least then, I am not wrecking decent tools, learning to sharpen/profile them. That is where my first area of uncertainty comes in- the lathe is complete except drive and tail centres.
I believe that the head stock is 1MT- I have measured the hole and it is approx 1/2". It certainly isnt 3/4" http://www.toolpost.co.uk/images/Morse_Taper_Sizing.jpg. Is a steb centre worth paying the extra for, or do I need a bog standard 2 or 4 prong drive centre? If relevant, I will likely to using offcuts, and blanks prepared from boards rather than logs or green timber. If I get into that, then I can get something more suited to that task if need be.
The tail stock end, which i forget the measurement for- I presume that a standard live centre will do the job as well as any other? If I use the steb centre, does it need anything different?
Mark
Mark
