toolsntat
Yep, I collect tools and tat
A Shell Auger, nose auger, pod auger, split nose auger (all the same thing) with lipped cutting edge should help here to pull in as you turn and cut.
Cheers Andy
Cheers Andy
Ah. Okay. Yeah, that gets pretty complicated. Sorry - wasn’t trying to teach you to suck eggs, just trying to figure out why the chamber couldn’t be drained...
All I can think of is the same as @Argus - something like a 8mm pilot hole to allow the centering bit of the augur to get continual purchase on something and to stop the augur just skidding on the face?
Good luck!
An auger bit is certainly the right tool but perhaps you need a slightly different pattern to assist with the very hard surface. I think you might need to keep sharpenning the bit or find something with replaceable tips.
I have seen some japanese pattern auger type bits with less "flat" at the bottom if that makes sense. These look like the sort of thing Star-M Japanese F-Type Auger Bit - Singles
Or perhaps something like the souber lock jig uses, it has replaceable carbide tips like a router bit brazed into it. They screw on to a smaller diameter bar which would reduce friction compared to a standard type auger and they go pretty long as well.
You can see the drills and replacement tips here.
https://www.morticer.com/en/dbb-morticer-accessories/
Ollie
How interesting. I’ve drilled and milled miles of green heart and whilst it dulls steel fast it never stopped them ( blades or drill bits )I’m working on a project that requires the drilling of very wet greenheart; it’s underwater, so there is no way around the fact that it’s wet.
Holes need to be 26mm diameter, c. 300mm deep. The drill is hydraulic. Auger bits have been tried; they cut nicely through the fist 30mm or so, then simply stop cutting in to the timber. Standard twist drills don’t fair much better.
Keeping in mind that these are being drilled free-hand, mid-water, and need to be accurate (so that the fabricated fixtures fit), I’m looking for possible solutions to this problem... any thoughts?
How very interesting, I milled up and drilled loads of green heart. Yes it dulled the tools . But never STOPPED them as you are describing.. Is it possible there is something like an iron plate reinforcement in there . Test with a magnet or possibly even a stud finder . Other than that I’d spring for a set of cobalt bits lubed with grease and see if they can pierce through whatever’s there . Keep us posted . Love to hear what finally works for you.I’m working on a project that requires the drilling of very wet greenheart; it’s underwater, so there is no way around the fact that it’s wet.
