clogs
just can't decide
John Hall
wouldn't know where to buy em here.....hahaha......
Hello,I should have asked earlier, are you using a drill press or trying to do this with a hand held drilling machine ?
If the latter, I doubt you will have much luck.
Drilling stainless requires relatively slow constant speed with quite a degree of constant force.
If you do it right, you will get a lovely spiral swarf from the flutes of the drill.
I have NEVER used any lubricant / coolant ( except when tapping threads ) - if you need that your drill is going too fast.
With such a thin material, I doubt you will need to retract the drill to clear the swarf.
I have never needed cobalt drills, just standard drills - sharp
Most of my work is with stainless, and just the other day I drilled an 18 mm hole - 35 mm deep with a standard drill and had no problems. I usually go up in steps of 4 mm
I had to remove the hardened metal and tidy up the hole with a dremmel and small grinder attachment. As you can imagine an easy job was in this case a nightmare of a job.Hello,
I am using a drill press, a Meddings, when I get back to my workshop next week I will give it another go at a much slower speed. I was using 3 in 1 as a lubricant. The drills were normal HSS newly sharpened. The metal is 316 stainless box section 100 x 50mm x 3 mm thick. I have now watched a few YouTube videos, one guy mentions the weld where you can get a hard area but I am pretty sure I had avoided this area. I do need to drill some 16mm holes for some large bolts when I get back. On one video using a hole saw was shown so I might get one 16mm size that fits my arbour. But then it looks easy on the video.
Regards
3 in 1 may be part of your problem.Hello,
Regards
My experience is that you do not want lubrication. The drill bit has to" bite " into the stainless to get a good cutting action. If you need coolant, your drill speed is too fast.
at is this ?I was tought go in slow n hard.....no coolant.....on S/Steel
Cobalt drills are really not that expensive anymore...perhaps 50% ......
I dont buy HSS anymore......
I have to drill hundreds of holes in angle iron and other carp steels, often up a ladder and overhead......
Sorry for the PUN but unless u have super branded HSS ^they just dont cut it).....
I've bought thousands of HSS drill bits over the years and even quality bits can often do with a lick on the grinder before use....
PS, as my holesaws wear out they are also replaced with cobal now....
come to think of it, my smaller HSS metal lathe tools have cobalt in em....most of the standard stuff I've given away.....
Sawtooth, have u tried the metal lathe cutting steel from Eccentric Eng, also of ur Parish, OZZ....
I'm quite impressed with it on my smaller lathe.....
These are really good on st/steel, we used them at work for cutting holes in pipe.for anyone still interested in the larger holes.....
I use these quite a bit...they are not expensive at all....
I bought a few just to see how they worked...
I was up a ladder 4m high drilling 16mm holes in 3mm thick Z purlins....
after about 50 holes they still cut fine...no coolant.....this was with a corded hand drill.....
my Mag Drill machine was to big n heavy to get in....
I normally use cobalt hole saws.....but they cut to slow....also now old school....
Keith 66
over a year I must drill 1000's holes..
Diy'ers drilling lumps of angle and god knows what else would benefit from Cobalt...
the best thing about Cobalt drill is the performance for a few pence more....
plus u practically never need to sharpen em...
How many on here can make a decent job of sharpening by hand a HSS bit....???
I've been doing it for 50 years and only 99% get it right on the smaller drills...
just getting old...
just for a laugh buy just a few reg sizes and try em, less than the price of a pint...
u'll be presantly suprised....
PS, if u can sharpen a HSS drill u can sharpen a Cobalt one...
