paulrockliffe
I've got some 4" x 4" workbench legs, I need to drill 4 16mm holes into the end of each leg to a depth of around 50mm, with the holes as close to parallel with the length of the leg as possible. I have a pillar drill, but while I can get the table out of the way, I can't see how to ensure the bit is perpendicular by clamping the leg to something, and the drill is mounted on castors, so the leg needs to be fixed to the drill really to avoid wobble in the castors.
The only 16mm bit I have is a flat spade bit, so I can't use a jig and a hand drill and I'd like to avoid having to buy a drill bit so I can do the job this evening.
Any ideas?
Any ideas?
