ColeyS1":2asiloij said:Anyone else wondering what it's for?
ColeyS1":2qwmasvf said:Anyone else wondering what it's for?
Sent from my SM-G960F using Tapatalk
AndyT":1u7lb8to said:I find this an interesting question. We now have no normally available method to do this, because the economic need to make long holes down tree trunks has disappeared. The Romans certainly did bore out trees to make water pumps. Roger Ulrich in 'Roman Woodwork' illustrates some alder logs from Vindolanda, 750mm long, diameter 250mm, with a 65mm hole bored through. He says they used a series of augers of increasing size to make them. Pipes like this - often in elm - continued to be used until the nineteenth century and a bit longer where they were vertical pipes down a well shaft with a wooden pump fitted at the top. I'm pretty sure the Museum of London has some on display.
There's a really good chapter in Walter Rose's 'The Village Carpenter' (1937) where he describes what was a very old fashioned procedure by then, boring new pipes. He says the men who did it preferred a conical style of auger which ran true in the end grain. Each boring was about a day's work for two men and they worked through a succession of larger and larger sizes, ending up at about 5 inches... or quite near to 120mm.
I've seen a set of these augers at a David Stanley sale, where I think I am right in saying the late lamented Richard Tomes bought them. Sadly we never got to see his own brand of historical re-enactment at this task.
I hope your project comes off, Roger.
ColeyS1":mglbwi4s said:Anyone else wondering what it's for?
No, not as far as I know, but polyurethane adhesives will. It's the only common form of wood adhesive that I'm aware of that will stick wet wood, with wet, by definition being wood with a moisture content greater than 20%, and dry therefore being a moisture content of ~19.5%, and lower.RogerS":2c5zuvq3 said:Does epoxy stick on green wood ?
I don't think a circular saw has enough depth to get the size of circle (after a quick sketchup)AndyT":2ka6pvmu said:That sounds like an open and shut case for splitting the logs and hollowing out by whichever method you prefer then gluing back together. The hole doesn't even need to be round; two long cuts with a circular saw on a bevel cut should let you make a long square-section hole which would be fine.
AndyT":24l0z5ro said:There's a really good chapter in Walter Rose's 'The Village Carpenter' (1937) where he describes what was a very old fashioned procedure by then, boring new pipes. He says the men who did it preferred a conical style of auger which ran true in the end grain. Each boring was about a day's work for two men and they worked through a succession of larger and larger sizes, ending up at about 5 inches... or quite near to 120mm.
