DRILL DOCTOR
buzzer
6 Nov 2010
It seems that this american machine is not made with 240 volt supply,it comes only with a 120volt 60htz does anyone know a way around this for the UK. ?
I have a very similar Drill Doctor in my workshop at school and it's a very good bit of kit. However, once you learn to sharpen drills by hand, you'll find that the Drill Doctor will sit unused in a cupboard for the rest of it's life.
My recommendation would be to find someone that can sharpen drills by hand on a high speed grinder, and get them to show you the basics, it really shouldn't take more than five minutes, and will save you a fortune in sharpening kit and drill bits.
I teach engineering to 14-18 year olds, and they really abuse the drills. I can honestly say that I've not used the Drill Doctor for such a long time that I'm not actually sure where it is any more.
My second recommendation would be to buy good quality drill bits. I now use Hertel bits sourced from J+L industrial and find that my students hardly ever break drills and I don't need to sharpen them half as often, whereas when we used budget drills, they were forever breaking drills, the budget drills were definitely a false economy!
Aled
This guy basically shows what you need to know, but as always it's always better to be shown first hand.
http://www.youtube.com/watch?v=DGibYeprpkk&feature=related
If you don't have a drill point gauge (who does?) it may be a good idea to cut a bit of card or thin ply to 118degrees (the most common grind angle) to help you along.
You won't get it right first time, but with a little practice, you'll find that you can sharpen a drill accurately in less than 30 seconds and then get back to work.
EDIT : This video goes into much more detail and shows exactly what you need to know. (It does go on a bit though)
http://www.youtube.com/watch?v=cqn2VPGYA9c&NR=1
Aled
Agree with Aled, learn to sharpen them by hand on a high speed grinder. Takes seconds when you know how - Rob
Has anyone tried the new drill sharpening jig for the Tormek? Looks interesting but I could buy a lot of drill for the price.
Andrew
What about brad point bits?
Can they be hand sharpened? Haven't been able to find anything in relation to them.
That's curious. In engineering forums, the consensus (not 100%) is that hand sharpening drill is quick and effective, but not 100% accurate, which seems "likely".
When a drill needs to drill more accurately "to size" they recommend grinding jigs (of various kinds, obviously).
BugBear
