Drill bits for router?
DrPhill
Cyber Heretic
15 Feb 2012
Directly above the center of the earth
Hi there, I am going to build a box for my flute. I expect to have to drill some holes with decent perpendicularity (is that even a word?). I don't have a pillar drill and my skill at drilling perpendicular holes with a hand held drill is legendary (for all the wrong reasons). I wondered If I could get a bit (1/4 inch or 6mm shank) to go into my Trend T5 router. That would keep the holes properly upright. I am not sure if such bits exist, or what to search for. I intend the holes to be for screws to hold the timber (cherry) together so something like 4mm for the clearance hole and maybe smaller for a pilot hole.
Or am I going to have to buy a pillar drill? I don't really want to as I have limited use and space for one, but.......
Any help or opinions would be valued.
{Edited typos}
Think about it some more, it is the principle ( horizontal drilling as opposed to vertical drilling ) that will work for what you want to do. I suspect more stable and accurate than doing it vertically too.The actual "machine" need not be precisely as Steve's machine.Easily adapted to be "makeable" as a temporary demountable device.take up no more space, even set up than a shoe box.
Maybe a drill stand? The type that mounts a hand drill as a sort of faux drill press. The stands look to be not-great quality but might get a job done for not a lot of cash or space.
Or just a drilling guide block, even cheaper and less space-eating.
{Edited typos}
There are straight drillbit-like router bits. Some are just like drill bits in that they're fluted. Upcut fluted bits will drag the waste out of the hole, just like a drill bit.. Search Amazon, Axminster or any other tool seller for "upcut spiral bit". If your Trend router takes 1/4" (6.35mm) bits, go for one of them. You can find them at many cutting diameters, from 3mm upwards. E.g.
https://www.amazon.co.uk/sourcing-m...y&sprefix=upcut+router+bit+set,diy,67&sr=1-20
Another option is a Dremel with an add on that keeps it at right angles to a surface, along with a small chuck and drill bits down to 1mm or even less.
https://www.dremel.com/gb/en/p/dremel-multipurpose-cutting-kit-26150565jb
https://www.dremel.com/gb/en/search?q=drill
https://www.dremel.com/gb/en/p/multi-chuck-0-8-3-2-mm-2615448632
Thanks Philk, Yes I looked at those, the stand or a cheap pillar drill might work. For the difference in price I think a pillar might make more sense than a stand. I could imagine a less than perfect fit between drill and stand.
The drill guides don’t fill me with confidence - especially for the finer drills. I could imagine the snapping rather than being guided.
https://www.amazon.co.uk/sourcing-map-2-Flute-Carbide-Engraving/dp/B0DLKT7QTP/ref=sr_1_20?crid=1NKQDKLPNAXVH&dib=eyJ2IjoiMSJ9.emuzLJj9ugrIVnxMS8d_tOYiLrxTabPB0GXLX278mdp4uzgqWexHbsdVms11aD-kw9olnZl3ShKpMmiXgFYAv6sL7xzD91BQBAXS5AGo1GXSv6xO-Mqbz8mOsFvw2MZ8-KlouOrnQwDZlCmPBQczQSpdM_KHnX1cyTtcrsx-tmtTPqsHlqjKW7p8NYfxRkyqdF9aYwQw7UithpL1VTs0nVOoGKTvXI95CQcGdD8846g.-gPqtzliKpOElsg0FLkqqps0MSCUObpRE6xbFgn1E8Q&dib_tag=se&keywords=upcut+router+bit+set&qid=1741987081&s=diy&sprefix=upcut+router+bit+set,diy,67&sr=1-20
Ah, thanks Eshmiel,yes that was what I was thinking of. I should have guessed that they would be a little more expensive than conventional drill bits.
It makes a pillar look a bit more attractive!
There are drill bits for the router, Trend used to supply them, in fact they probably still do. The ones I have had in the past had carbide tips with a counterbore to the top.
