A die grinder and yes I have one is no good for very small thingsmemzey":dqgfku38 said:I don't get what the difference is between these and a regular die grinder? If you have an air compressor there are many cheap die grinder kits available and in my experience air tools tend to work well and last longer than portable electronic hand tools.
Mine failed on the third use. No problem getting a refund, but it's not a quality product.graduate_owner":3aeaot64 said:I don't like cheap tools but I bought a Dremel type from Lidl when they had a special offer on. It doesn't get much use - hence the decision to get a cheapie, but it seems to work fine.
Alexam":3v2k6scf said:Thanks Jimi, that's a good price. Do yo use the Proxxon only with your CNC,which presumably would be mounted, or use also using it freehand ?
Alex
Alexam":gqcx3h2d said:Hi Rob, which models of Dremel and Proxon do you have and can you say in which way the Proxon is more capable than the Dremel please? What do you mainly use these tools for?
RobCee":3h3avu65 said:Alexam":3h3avu65 said:.........I originally used my Dremel in a home built CNC machine, but have since upgraded to a Chinese inverter driven spindle (which gives me ER11 collets) that is more suited to the CNC environment. I did break one Dremel's spindle locking mechanism and the run-out was awful for precision work, hence the upgrade.
