Hi,
For my wardrobe, I am going to be making 16 drawers with a fairly simple construction. I will be cutting the front and back slightly shorter so that I can screw the draw bottom up into them. The sides will have a recess about 2cm up for the draw bottom to slide into. The front and back will then be pocket screwed into the sides, all glued.
They will be roughly 78cm (w) x 50cm (d). Height will range from 22cm tall to 15cm.
Given the size, and the relatively low weight each draw will carry, what thickness Ply would you use for both the draw, and then also the draw bottom?
