Tset Tsyung
Hey all,
I've got an old draper hobbyist table saw with an 8 1/4" blade on it. I've sharpened it, but now realise that the most important bit to sharpen would be the actual tips of the points as this does most of the cutting... right?
Anyway, the problem that I'm having at the mo is that whenever I run a piece of wood through the table saw it veers away from the guard (to the left). This means that if I try to keep the wood flush against the guard the blade bows inwards, towards the guard, causing problems such as not cutting straight, pressure on the blade causing friction/slowdown/motor-overheat and finally my stress levels rise. As I suffer with CFS (Chronic Fatigue Syndrome) AND working with a dangerous tool this isn't ideal, lol.
Could it be that the fact the teeth on one side of the blade aren't that sharp be causing this problem?
I'm using this to trim down a branch that needs one side to be flat - would I better off working with a power planer?
A really appreciate any help. I know I ramble a bit so I'm really sorry for this lol.
Many thanks (in advance),
Mike.
Mike.
