devonwoody
Thanks for that, now where did my junior hacksaw go, its dropped off its perch the last time I looked for it.
Jacob":j157l25s said:In fact the metal cutting blade does a very clean rip cut. I bet the 14 tpi wood cutting won't be so good for DTs but will be better for cross cutting.
Probably yes. Why would you want to do that?Mikey R":1cop7e3m said:Late to the party as ever, sorry guys - if you use a rip cut wood cutting hacksaw blade and grind it so that its less deep, arent you basically using a coping saw?
Like a very fine tooth coping saw or fret saw? What point are you trying to make?bridger":158hsqr7 said:so a hacksaw is a metal cutting bowsaw. if we made a deep enough hacksaw frame stout enough to take a lot of tension, ground off most of the set on a hacksaw blade and mounted it tight, how would that cut?
Jacob":3o9f49zc said:Like a very fine tooth coping saw or fret saw? What point are you trying to make?bridger":3o9f49zc said:so a hacksaw is a metal cutting bowsaw. if we made a deep enough hacksaw frame stout enough to take a lot of tension, ground off most of the set on a hacksaw blade and mounted it tight, how would that cut?
Junior hacksaw blades seem to be 32tpi with no fleam, which is why they can do a decent (small) DT cut. No need to modify them.
Well yes - go for it!bridger":3tlvjr1z said:Jacob":3tlvjr1z said:Like a very fine tooth coping saw or fret saw? What point are you trying to make?bridger":3tlvjr1z said:so a hacksaw is a metal cutting bowsaw. if we made a deep enough hacksaw frame stout enough to take a lot of tension, ground off most of the set on a hacksaw blade and mounted it tight, how would that cut?
a coping saw with a wide blade. grinding off the set should reduce the squirrily steering. I guess the point is that a dovetail frame saw isn't a completely crazy idea, and a hacksaw isn't an impossible place to start. aside from having the wrong blade and the wrong frame, that is.![]()
