OPJ
Hi guys,
I've started machining up some English Cherry for a wall-mounted bookshelf with dovetailed corners, 1000m tall x 600mm wide. The joints at the top will be half-lap/half-blind dovetails with throughs at the bottom. Timber has a finished size of 230mm wide 22mm thick
Trouble is, I've had to join two boards edge-to-edge in order to get the width. As I don't like centrelines though, I decide to offset the "centre"-line by 10mm... I think it works quite well (I've already done this part in the workshop!) although it isn't that obvious.
Anyway. I'm assuming it's best to have a tail rather than pin over the join but, I can't decide how to arrange the rest of them.
Should I keep them all uniform across the 230mm width? If so, how would you do this marking out the tails first?
Or, should I try something different - in which case, I'm open to ideas and suggestions! :wink:
Here are the throughs:
And the half-laps:
Any thoughts or suggestions would be much appreciated,
Olly.
And the half-laps:
Olly.
