Dovetail jig
Davegg
New member
22 Dec 2024
Newcastle Upon Tyne
Hi,
I am after some advice on he above Dovetail Jig. I have recently bought a Trend T7 Plunge Router and was wondering if this would work with the Porter cable Dovetail jig. If so would I need to buy anything else as some of the other jigs such as the UJK one require you to buy a unibase to make it compatible. Advice would be greatly appreciated
Thanks Dave
Most of the jigs for dovetails require you to have a unibase which then allows you to fit guide bush to use the jig . I have no knowledge of porter cable but theirs is unlikely to be any different to the rest of. Again most makers give instructions on what else you need to use the jig .
According to the porter cable manual your router must accept their template guides, see screen shot below.
Is there any reason you particularly want the porter cable one? If you went for a European make it would use metric guide bushes which should fit directly to your router.
I used to have a Bosch dovetail jig & if I remember correctly it just used a 16mm guide bush that fitted directly to my DeWalt router.
On the Axminster jig it comes supplied with a top mounted bearing straight cutter. So that size of template cutter will do, and as the Ax jig is just a generic model, i would think the same template cutter would work on a range of jigs
Said cutter - For the Axminster/Axcaliber
https://www.axminstertools.com/axca...-x-19-05mm-s-1-4-6-35mm-bearing-12-7mm-666106
Jig -if its identical to this one then thats the cutter you would use.
https://www.axminstertools.com/axcaliber-dovetail-jig-502514
I am new to this so are all unbases the same or is there as specific one I need.my router is a Trend T7. Or can you suggest a good jig. The reason I liked the porter cable jig Is that all the templates are included.
Hi, ive just had a Quick Look at the T7 spec. looks like it's more on the side of hobbyist routers so some adjustment maybe needed to be done to the base.
I found this post which seems to support my suspicion, but i'd say the easy option for you would be to grab uni base, get it fixed on, and just use the router from now on with the uni based attached, but the collar off, unless you are using the dovetail jig!
Hope this helps!
Adam
I have the unibase, had it for years, I had thought - but I didn’t check that the T7 would be compatible with the trend GB system.
The Unibase can be made to fit, it uses the holes which attach the dust collector, which is a complete pain. There is a semi captive nut system in the plastic of the dust collector. It is very easy to drop the nut and it then lands in the motor Housing.
But tbh if I were you I wouldn’t bother I’d save the money on the unibase and buy a better router
If you own a Trend T7e router it will not work with thee Porter cable 4216 due to the router guides, having the Unibase 180 won't solve the problem
If you want to make drawers pls don’t do what I did, three different heights of drawer fronts with through dtails at the back and lap dtails at the front.
Having to reset the damn thing up 6 times, it would have been quicker gnawing the joints with my teeth.
Ian (best of luck).
I'm afraid I can be of no help for jigs, but I'll point out that it's worth also giving dovetails a go by hand. I started proper woodworking a few years ago and it turned out that handmade dovetails are MUCH easier to make than they appear. It took me a few attempts, and I had to learn to saw straight (which you should learn to do in any case), but I was very quickly able to make mostly perfect dovetails.
Unless you have a large number to make, you can be surprisingly fast with just a saw.
Must say that I bought a leigh jig back in the early 90s, when they were still a new thing. I've used it a fair bit, but TBH, I found like most of these type of things they were a bit fiddly, and time consuming. They also mean using the router, which while very useful is something I came to hate because of the noise and dust.
As you say, a bit of practice, and you can be surprisingly fast with just hand tools.
Less room for error as well IMO.
