Mr T
Hi
Just finished this chair:
[/img]
I expect you can guess why I called it the Domino chair. It's in euro oak, burr oak and the slats are fumed oak. It was designed by committee! David, with whom I share a workshop, and I both submitted designs to the customer. She then picked bits from both designs and added her own touches as well, the burr buttons are hers.
We are just about to start on a big kitchen job so I went out and bought a domino jointer, this was the first job I used it on. The legs and rails are all dominoed, the back slats are tenoned into domin slots in the bottom rail. The buttons and slats have a 6mm threaded steel rod through them glued with West System into holes in the uprights.
I thought creating the buttons was going to be tricky, but it went quite well. I veneered up some oak over width, then grooved either side to take the slats, then I routed out the ovals using a 6mm bit and guide collar.
[/img]
Very impressed with the domino, even if I do feel deskilled, it did mean the job came in on budget for once!
Hope you like it.
Chris
[/img]
Hope you like it.
Chris
