Hi all
Just looking into woodworking joints and the different methods and tools around to compare everything possible and got a few questions for people familiar with this one.
I currently use a combination of loose M&Ts using a woodrat and router table plus a Dowelmax for doweled joints. The dowels are 10mm diameter and I aim for about a 60mm insert depth into end grain.
The 700 plunges to 70mm which is very handy, and there are a range of cutters albeit not cheap. How tight, accurate does this cut the mortice as I have noticed it has a setting for a wider/sloppy mortice that if it is accurate should not be needed?
Do people just buy the Domino biscuits which compared to dowels are extremely expensive or run stock through a router to produce their own which is what I currently do for my loose tenons?
I have also seen an adaptor for the 700 to allow the use of the smaller cutters from the 500, I know Festool are not happy because it makes the 700 more useful and the 500 less so but anyone any experiences down this route. I gather someone had some issues with a machine but cannot see why, if it can use a 14mm cutter and plunge to 70mm then using a smaller cutter is not going to make it sweat.
Any other info or experiences appreciated.
