T.H.
Good evening all. I’m new on here so “hello” to everyone & I’ll fire right-in with my first post:
Anyone on here familiar with the Dominion DAA planer & thicknesser machines? Just purchased a 16” x 9” which I estimate to be an early eighties model. I received no manuals etc with it. I’ve just some sales literature & a basic Wadkin/Dominion manual courtesy of Daltons Wadkin. The machine was being occasionally used by previous owner & is in pretty good shape overall. It just needs a few small jobs before being put to work & would appreciate some info as follows.
1) Are the threads BSW type? It needs new 1/2” female clamp levers x five plus some 5/16” x 1” Allen grub screws for the planer beds. If I can’t get BSW levers some new 1/2” nuts will suffice.
2) Gearbox needs fresh oil. It’s almost dry but can’t see evidence of a leak & it seems to function ok. Is a multigrade oil suitable, 75W140 for example? Shows BP Energol 150 in manual but there’s a big seasonal difference in temperature where I’m based so thinking the multigrade will be better. Also, what’s the oil fill level on these, just above the gears?
3)The Brammer belt & rubber ‘vee’ drive-belts are good but the two drive-chains are not. They seem well stretched or they’re an incorrect fit. They’re both Renold ‘Elite’ type & seem to measure as a 415 chain or #42 chain, 1/2” pitch x 3/16” internal width x 5/16” diameter roller. Does anyone know if these are the correct type? I’ll simply order replacements if all is good.
Any assistance or info is highly appreciated.
Many thanks,
Tony
Many thanks,
Tony
E84F70F8-143A-4F49-85A8-9C50BBF401C4.jpeg170.6 KB
0B684EBD-38C4-4BE4-BCA6-3622D1419CEF.jpeg128.3 KB
50CB5EF9-BD83-45A3-90F6-D2F91AEB0EC8.jpeg214.4 KB
7D3E129D-F037-41CC-BAE2-F62C94557F08.jpeg81 KB
DB260805-FA2B-4C58-9B91-614FF06F485A.jpeg68 KB
5AB39AF6-9D1A-4FEC-9C53-BE49DA227387.jpeg186.7 KB
8FD615F1-32CE-467A-B53F-2A697EC605A3.jpeg137.6 KB
8277B986-6D2A-4D59-913B-95D2A85309AC.jpeg179.3 KB
