brianhabby
I thought it about time I built this doll house I've been promising to do since my daughter was born 35 years ago...!
I am now building it for my granddaughter
I bought some plans from a firm called Hobbytrends and used one of these as the basis for this house. When I dug the plans out I found they are for 1/16th scale and I wanted to build this house to 1/12th scale since much more stuff is available in that size. So I took all the measurements, divided by 3 and multiplied by 4 - it seems to work.
So after cutting out the plywood panels here is Dale (my grandson) cutting out some of the window openings:
Much as I would like to make all the parts for this house, I decided that it simply isn't worth the effort for a lot of the fittings when they are so readily and cheaply available. So all the windows and doors have been purchased from a local toy store. Here we are ready to start putting the pieces together:
All the main pieces will be glued and pinned:
I cut trenches in the walls to take the first & second floors:
It was only after the glue had started to set up that I realised I had dropped a major clanger
Until next time
regards
Brian
Until next time
regards
Brian
