Does anyone recognize this local timber?
BentonTool
UK Tool Junkie...
UKW Supporter
15 Mar 2024
Benton, Pennsylvania, USA
Hello Brothers,
I recently harvested several pieces of a local "trash" brush that I have cleared as unwanted undergrowth for many years around the farmstead.
There was some of this growing on our church property that was larger than I had allowed it to grow, so I brought some home.
As it turns out, when turned, I found it to be amazingly dense, and takes a very high polish/sheen.
There are no visible pores, and it has many colors: white/ivory, tans, green, and browns.
I do not have any pics of the bush as harvested in winter, nor do I have any of it in leaf, but I will certainly photograph it in future, in order to attempt to identify it.
I am amazed at how well it turns, and how smooth it feels in the hand.
However, the pith is rather large, it checks badly, and has many inclusions.
It looks something like samples of Olive that I have see (?).
It looks very much like a Cotinus species but I'm not 100% about the bark. Over this side of the pond it's known as smoke bush or Venetian sumach
Do you know if anyone harvests this timber for small projects/woodturning?
I will look up the Cotinus to see if it grows locally.
Thank you, much appreciated...
P.S. I got the ferrule to fit better after taking the pics... :)
I've never seen it for sale as wood, usually only see the purple leaves one as a garden plant to about 12ft tall
I looked it up on the net. Cotinus does not look like the wild underbrush growing around here.
I am looking forward to the Spring; when it leafs, I will more easily be able to ID it.
I was thinking that perhaps some of the local turners might have experience with this timber. Harvesting it for their personal use. I think it is far too small for commercial enterprises.
Thanks again.
Second guess is Black Locust, a weed tree in many parts of the US I gather. Suckers prolifically so can easily form thickets of scrub. Some years back there were experiments in growing it for lumber as a possible replacement for oak for framing but I don't know if they came to anything
My first thought was Robinia which shows my ignorance. I didn't know Robinia and Black Locust were of the same family. If it is Robinia, it also grows in the UK, especially around here by the river and canal where it can be quite invasive. I've turned several burr bowls from it. It should have a slightly waxy feel to it. Before the sun changes it to brown or cream the heartwood may have a slight green tinge. I left the burrs in storage for around ten years before turning. The woodworm had a field day with it all but in this instance, I think it added character.
Got one in the garden. Shoots like a good 'un as soon as your back's turned.
Very distinctive smell when you (try to) cut it back to control it.
The smell is like something else that I can't think of.... acid drops, maybe? Can't remember, but no doubt I'll be out there with the secateurs in a few weeks!
It immediately made me think of Box, but the colours not quite right unless that’s the sapwood? I’m sure you know that Box is traditionally used for the best chisel handles.
The bark looks a reasonable match to this one too.
Re the pith, it’s normally split into 4 to avoid it.
https://easternleaf.com/bonsai-japanese-boxwood-bonsai-tree-p/800620-03.htm
I love Boxwood (who does not? :D)! Yes, the grain (or lack thereof) is much line Boxwood, and turns in a similar manner. I have risked turning the smaller pieces with the pith intact, risking the splits, but so far, it has worked out well. The splits on the smaller pieces have been minimal, and controlled with ferrules on each end. Additionally, this bush is a deciduous plant, not an evergreen. Sadly, we have a scarcity of Boxwood in these parts of the colonies...
I harvested some Black Locust (in the same area), and found the grain to be coarser, with evident grain and pores. Black Locust (in these parts) had a reputation for being very dense, heavy, hard, and rot-resistant. Most of it ends-up as fence posts, and is much admired in that role.
I spoke too soon (re: splits):
This happened overnight. :ROFLMAO: The second ferrule helped a little.
I will fill the split with epoxy and finish it.
Let's see how that goes...
Is it thorny on the young growth? White pea like flowers?
I went back and harvested a bit more of the mystery timber. Please refer to pics below...
There (nearby) I also found a patch of what I think is called "Honey Locust" around here.
(I just spent ten minutes pulling out an embedded thorn from my finger...)
The Honey Locust is smaller (more of a bush) than the Black Locust (which grows large, I have seen some 8 inch diam. trunks), seems to have a much finer grain, and is more dense than the Black Locust trees.
Thanks for the tip! I might not have harvested it (the Honey Locust) had you not brought it to my attention.
I am looking forward to turning some of it!
(P.S. The mystery bush has no thorns, but the Honey Locust certainly does!)
(P.S. 2 The Honey Locust apparently have multiple thorns together whilst this bush/tree has single thorns. I may have to wait until they leaf & flower to be sure.)
After a little research, it is possible that this bush is one of the honeysuckles (genus Locinera):
Bush Honeysuckle (Lonicera maackii)
Fragrant honeysuckle (Lonicera fragrantissima)
Morrow’s Honeysuckle (Lonicera morrowii)
Other genus Lonicera = Lonicera tatarica, Lonicera bella, Lonicera standishii.
Look-alikes:​
Fly honeysuckle (Lonicera canadensis) and other less common native shrub honeysuckles (Diervilla lonicera) all have a solid pith rather than the hollow pith seen in invasive species. Native snowberry (Symphoricarpos spp.) has a similarly hollow pith, but its flowers are small, pink, and bell shaped, and the fruit is white. Native viburnums (Viburnum spp.) also branch oppositely, but they have toothed or lobed leaf margins and solid piths. The leaves of native dogwoods (Cornus spp.) have smooth margins and can look similar to honeysuckles, especially L. maackii, but dogwoods have solid piths and their stem/growth forms tend to be distinct from the invasive honeysuckles.
Hello Brothers,
It looks somethi
Laburnum?
I am becoming more confident that the mystery shrub is one of the honeysuckles.
There is quite a bit on the net regarding turning honeysuckle.
These videos may be of interest:
https://extension.psu.edu/shrub-honeysuckle-accurate-identification
That would fit the 'stringy' bark. We have fewer species here and they don't usually get that thick. I'll have to look out next time I'm in the woods here.
Honey locust sounds as vicious as our blackthorn, which also has a great wood for turning. Will look forward to seeing how it turns
