Do you use a back saw with crosscut teeth?
Paddy Roxburgh
19 Jun 2014
Enfield Lock
I’m curious to know how many of you use a carcass saw/back saw with cross cut teeth, or do you use your rip filed tenon saw/dovetail saw for the cross cuts in dovetails and tenon shoulders?
I have a couple of crosscut backsaws I use mainly for cutting small boards to length. I use them in place of a mitre saw that I got rid of a year or so ago and haven't missed for a minute.
In fact they are probably the handsaws I use most. I use dovetail saws for intricate work and obviously dovetails. The back saw I use least is my rip cut back saw, though I'm glad I've got it.
I also have crosscut panel saws for larger boards.
I'd definitely use the crosscut backsaw for cutting tenon shoulders. But dovetail cuts tend to be small and I'll usually use the saw in my hand at the time - typically a dovetail saw.
I have quite a few hand saws. They are very cheap second hand. I bought a box of back saws for a fiver at an auction and have picked up most of my panel saws at a local house reclamation store very cheaply.
I'm trying to teach myself saw sharpening so having a few I don't mind junking is very handy.
My aim is to have two larger back saws (14"ISH) one cross and one rip cut. Then two dovetail saws, one 15 tpi and one 20 tpi. One day I hope my sharpening skills will be good enough that I can get rid of the extra ones I have.
Anything over 15 tpi can just be filed rip.
I end up using a 15 tpi crosscut backsaw for both tenon cheek cuts and shoulder cuts. One less saw. These are all for furniture, so rarely have even a three inch tenon. File it a bit on the aggressive side. I don't want to be the joker who stands in front of a display of fifteen + saws deciding which one I'll use today. A crosscut saw makes short rip cuts more than competently.
Agree with that.
Ive got a Veritas Carcass saw, which was originally 14tpi crosscut. I sharpened it a few times, keeping it crosscut, but I eventually started filing it rip with a progressive rake. Much easier to sharpen and even though its a tad coarser than 15tpi it still crosscuts very nicely.
Agree with that.
I still like crosscut -- seems like 15 ppi rip would be a little too grabby on small mouldings and other assorted thin, narrow pieces when crosscutting. But whatever works for you.
I have a 10" backsaw that I filed for crosscut (about 13-14ppi), but I don't really think it's worth it. It's slow, and I find I get a similar result with my dovetail saw (10", 13ppi rip) or with some woods even with my tenon saw (14", 11ppi rip). Especially in hardwoods, I find that small rip teeth work just fine, particularily if I mark the line with a knife. Even in softwoods, the result isn't too bad, and barely worse than what you would get from a dedicated crosscut saw.
If a need an extremely clean crosscut straight off the saw I can grab a dozuki that I rarely use.
Otherwise, I find the Paul Sellers advice of filling everything finer than 10ppi rip to work for me.
