...would be able to hold its own even-up with boutique chisels? A2/V11 whatever? (that is with skilled rehardening, not just someone taking their first shot at rehardening).
I've generally felt like most of what stanley is using (this isn't true of later cheap tools) around WW2 or before has a feel like it's got plenty of carbon. What that translates to is that the tools are less hard than they could be, and Stanley chose to use good stock and do that rather than make slightly worse tools with lower carbon steel maxed out in hardness. Since they're more or less site tools, or sold both for bench and site work, the choice of hardness seems a compromise for hand grinding and honing with natural stones.
What triggers this thought (are they actually just as good, just need hardened to a different spec)? I read fairly often that stanley chisels don't perform that well compared to modern chisels and that the "steel isn't as good" (this is actually true for most budget chisels now, never seemed the case for most older chisels unless those are off-brand stuff).
