I've just completed a lot of dowel edge work and found this one from Rutlands ideal. Unfortunately it doesn't look as if it's in stock.HTH.Hiya,
I'm after a simple dowel jig, I've seen this one online and on you tube, just before I buy it asking if anyone has one or has made one and worth it or completely stay clear?
I'll be doing edge to edge work 99% of the time.
Cheers.
I bought one of these from Rutlands recently.I've just completed a lot of dowel edge work and found this one from Rutlands ideal. Unfortunately it doesn't look as if it's in stock.HTH.
Hi Chris.
From the outset let me apologise if I'm over-simplifying your needs.
I understand that you will be doing mainly edge doweling. The attached shows a very simple doweling jig that
can be made fairly easily and is perfectly accurate every time.
This Woden set looks like a better engineered version of the Stanly where the guides are Singles and are just clamped in steel tubes, again they would be imperial sizes I guess?I used a Woden for end to end and for pattern guides I used screw in guides you can make up your own base and set them wherever you need them.
All are now spare no longer need them
The Joint Genie is a good tool - accurate and versatile - but I constantly find myself thinking that a few simple changes would make it so much better. Why not, for example, thread the transverse holes used to hold the shims? And why not supply proper thumbscrews for the end tabs (I’ve done that anyway)? And a bit of engraving (marking L and R sides, numbering the dowel holes, perhaps). I’ve made and 3D printed some add-ons that make the device much easier to use.That's not going to be very flexible, and not easy to line up exactly. I use a joint genie. The JG lines up exactly, and gives you a lot more options re hole placement. Will be a lot more costly than the rutlands one.
I think I've seen someone on YouTube make something similar to the the rutlands one.. maybe you could make something cheaply just to trial the concept?
Same here, the Dowelmax is very precise and it's only drawback is that it can be very slooooow. An issue with the banggood version is accuracy, the five dowel holes must be identical from both ends which the Dowelmax is, any error is noticed when you do the opposite side holes and have to reference from the opposite end and is where the cheaper ones fail. It can also take a bit of getting used to initially, you must not overthink it which is to easy to do rather than just stick with the ticks.I've been using a Dowelmax for many years - expensive, but very accurate, for a multitude of different joints. I believe Banggood do a 'rip-off' version.
