MikeG.":1z0trh0m said:Having a PT doesn't remove the need for hand planing. If you have a board in wind, for instance, you still need to flatten it.
MikeG.":1ndgmitf said:Having a PT doesn't remove the need for hand planing. If you have a board in wind, for instance, you still need to flatten it.
Yes with some dexterity you can take the corners off to remove the wind. Don't need a particularly long bed for that.deema":krpof3ly said:MikeG.":krpof3ly said:Having a PT doesn't remove the need for hand planing. If you have a board in wind, for instance, you still need to flatten it.
Well, I find that both boards in wind and bowed with a little practice and good technique can be flattened easily and successfully on a PT. I do use a scrub plane if the stuff is very big and heavy just to reduce the effort of lugging it backwards and forwards.
Isn't it the aim of the planer to do that ? I agree that for extremely twisted boards a scrub plane is useful to knock of the high spots, but never had issues flattening twisted boards with a "standard" PT. Just need to be careful about the board positioning.MikeG.":uqv59wou said:Having a PT doesn't remove the need for hand planing. If you have a board in wind, for instance, you still need to flatten it.
Lons":upto67qh said:I can't say I enjoy using a planer thicknesser, noisy, messy and certainly don't get the buzz of satisfaction I get as a sharp handplane "sings" across the wood surface
Trevanion":14sdwp7j said:the machine purring and the sound of wood being cut, wonderful.
