Stevie B
Hi Guys
I'm just making a built in cupboard and for the doors I want to lay 9mm mdf over 15mm mdf to create a shaker style door that'll hopefully be a bit stronger than laying 9mm over 9mm which is what I usually do and very often the doors end up bowing which is very annoying.
I usually use the standard blum inset or overlay concelaed kitchen hinges but I don't think they will work with 25mm ish thick doors so do you guys know of any that do?
The doors will be overlay just like a kitchen unit and will have a side trim on each side which will be the same thickness as the doors so it all runs flush into the walls.
Any ideas or other hinges that I could use would would be greatly appreciated.
