Third in a great You Tube glue myths series has just landed. Worth a look if, like me, you have a biscuit cutter.
I quite agree, and suspect that maybe he will go on to examine splines, dowels and dominoes.I was always told biscuits were for alignment not strength so no real surprise, It would have been far more interesting if he’d used dowels or even dominoes
There have been many over the years.I was always told biscuits were for alignment not strength so no real surprise, It would have been far more interesting if he’d used dowels or even dominoes
I have used biscuits in architraves around doors for years now and not a single one that I know of has opened up.surely the problem with joint failure(at least the type he's talking about) is the movement of the wood over several seasons. mitres in particular show big gaps ie the angle changes at the inside corner. so biscuits seem to stop immediate breaking.
Yes I have seen biscuits used by guys installing fancy trim work, for alignment and help hold it in place whilst glue dries. They do have a place, been around a long time.I have used biscuits in architraves around doors for years now and not a single one that I know of has opened up.
This is true & possibly why he found the shearing in the biscuit.I have not finished watching it but so far he's testing at exactly 90 degrees to any strength the biscuits are adding.
Another typical use of a biscuit will be to transfer the load on a shelf to a side.I use them for two reasons - 1/ for alignment, and 2/ to help stop a butt joint pulling apart. The way he was breaking those joints is largely irrelevant.
Me too. Like me I am sure you only use well-seasoned timber. You can't really prevent a mitre-joint from opening if the wood needs to shrink, but if the glue to the biscuit is really good, it is possible to split the wood instead. When biscuit jointing thin timber or mdf I clamp over the biscuit itself if I can which vastly strengthens the joint. Tightness of joint and thin glue-lines add to strength immensely. The simplicity of the joint is marvellous, I wish they were available in miniature, with smaller saw blade but still with similar depth of cut for narrower joints.Yes I have seen biscuits used by guys installing fancy trim work, for alignment and help hold it in place whilst glue dries. They do have a place, been around a long time.
