DIY tree stump + woodworm project
dasa
New member
17 Jun 2014
london
hi guys
I have bought in a huge tree stump into my new flat , with wooden floors withe the idea of making into a coffee table. It has saw dust in the centre, and am now learning that this must be wood worm. is this a huge danger to my flat-do I need to remove immediately or can i treat it over the next few days and then work on it?
Apologies, I have never tried to do a project like this before am very ignorant.
Any advice or help would be hugely appreciated.
thanks,
Amrita
The rule of thumb with furniture beetle (woodworm) is that they will only infect damp wood. So in theory your nice centrally heated flat should be safe. However, if they get in the roof space or under the floor and something down there has a higher moisture content then there is some risk. Apart from anything else, isn't it going to make a **** of a mess indoors if you plan to start cutting, shaping, sanding?
Wonder why they're called 'Furniture Beetle' then?
Woodworm attacks 'Seasoned' sapwood, not heartwood, so that is why it is found in pine floorboards (dry) and older houses where a lot of sapwood was used in roof and floor joists, they love starchy timber like Sycamore, if worm holes can be seen and there is woodworm dust appearing then a treatment of woodworm killer is recommended (outdoors) pour it on and let it soak in, it will take a while for the smell to dissipate but it may be worth doing just for security reasons.
Andy
Firstly saw dust in the center could be any thing, can you see flight holes with the dust as this is where they have left in order to lay eggs and then die. holes in the bark , could be bark sap beetle wont, harm timbers in flat. Very small flight holes could be powder post beetle and would not spread to flat. Furniture beetle (Anobium Punctatum) however started in the forest in dead timbers and spread into homes in the early 1900's when plywood was first manufactured, - the glue used in the veneers of early plywood was high protein animal glue, which they (the woodworm) really loved. Since then they have spread into all house timbers including oak if it is a little soft (damp). Other timbers including furniture needn't be damp as they really go for the cellulose in the sapwood. They can stay in the timber for 3 to 4 years and only make the flight hole (commonly seen but they are already in there) when they change into a beetle and exit the wood, they generally leave between May and the end of July, but central heating in homes can alter this. Any woodworm treatment fluid will only kill the woodworm where the fluid has penetrated, and will not kill the remainder lying deeper in the timbers until they go to leave the wood, and they eat the treated timber over the next 3-4 years on leaving.
Of course if you treat any timber and then sand or cut any of the wood in order to make your coffee table, you will have removed the treated wood, so therefore if it is indeed woodworm the coffee table should really be made outside, and once completed prior to applying any sealers of any kind it should liberally treated with all over with commercial woodworm fluid following the manufacturers instructions. Also remember these chemicals are highly toxic and should only be used in ventilated spaces wearing protective gloves as they are harmful by skin absorption as well as inhaling, young children and pets should be kept well away until the treated article is thoroughly dry. Once dry and sealed with varnish or sealer the item is safe. Hope this helps..... I actually ran a timber treatment company for many years, hope I haven't bored you with too much technical info.
