My next project is going to be a Router Table which has been inspired by a few of the builds featured on here and also Norm's ubiquitous item. I have a parking bay in the end of my garage with a large tray style drawer above holding various power tool storage boxes so the overall volume is dictated by this; 1150mm wide, 700mm deep and 940mm high. The space is currently occupied by an old and somewhat wobbly workbench on decent locking castors; the castors will be transferred across but the rest isn't fit for much else. I will be mounting my Trend T11.
Carcass will be 18mm ply (I have 3 sheets of birch ply at home already), the blue elements are T Track which I bought for another project but never got round to using, these will address fence adjustment and mounting on he fence for feather boards and the like. The gold rail is Woodpecker Combo Track which I'm hoping will be very versatile. The insert plate will probably be the Incra Magna Lock unless anyone has any better suggestions.
I have just about finished the top of the table which is a lamination of 2 pieces of 18mm MDF, I set out a gridwork of clearance holes for screws, placed the upper sheet face down on the remaining MDF on my known flat work bench, added the glue and then the bottom piece, the screws were set from the centre out and the whole lot was left overnight to dry. On close inspection the following day there was a slight crown to the top but I can only assume it was due to slightly asymetric drying of the glue because a day later it was perfectly flat again. The top and bottom were then faced with gloss white Formica (I bought a 1200x1200 sheet from a trader on EBay); I used EvoStik Timebond for this task since it allows a degree of adjustment provided that you don't apply pressure until you are ready. This was again smoothed from the centre out to remove any air bubbles. A triple flute triming bit was used to tidy everything up. Finally I ripped and hand planed some oak architrave left over from our extension build to width, mitred the corners and used glue, brads and most of my meagre clamp collection to fix.
The top to date resting on my Ron Paulk inspired modular workbench:
Quite pleased with the mitres straight of my DW708 SCMS
I have a few details still to resolve before I start cutting plywood and a couple of questions for the experts on here:
- I have allowed 75mm of overhang at the front and sides for clamping; is this enough and do I need a rear overhang?
- Is there any need to hinge the top? My Trend T11 has through base depth adjust and when funds allow I intend to treat myself to a second router (Festool OF1400 top of list).
- Best location for the insert plate, at the moment I have it central left to right and slightly back from centre. Pros and cons of alternate locations.
- The fence will be made from 18mm MDF with sliding cheeks topped by a fixed section carrying T Track; is there any need to face both sides of the cheeks to prevent warping.
Thanks for looking, I'm sure hat plenty of other questions will present themselves as it starts to take shape. The project probably won't move too fast since I have 2 rooms to build as well.
