devonwoody
I started on fitting the hinges and found that the brass screw heads are oversized so drilled with a bit to largen dimensions, however there was a soft spot and the drill went completely through the countersunk area and now the screw will not hold at all. So I intend to put a screw in anyway and then solder its head to the hinge. Any better ideas please advise, (hammer)
Pictures below shows how I held the hinges doing the above operation.
Cannot show you the result today of fitted hinges They will need some more adjustment to correct some problems. (sorry about that one but it was bad)
However I did glue the other side to back frame. (The tin of preservative is just a counter weight so the job did not fall off the bench)
