Disassemble and reuse wooden handrail
ukworkshipper
29 May 2024
Off the island
Hello folks!
I have removed a rather solid oak old-style staircase during our renovation but hate wasting good quality material especially wood, and always try to recycle and reuse wood.
I have tried to sell the staircase for very cheap, the few interested buyers couldn't transport it, and asked me if it could be disassembled. I think it's unlikely it can be sold so I am wondering if anyone has any good idea on how to reuse this wood. Can I build something useful or cool for my garden? Any wild idea to share?
And how do I disassemble it without sawing the whole thing apart. Can the handrail be detached from the balusters or do you think it's glued? The handrail is about 2,50m and the baserail 3,50. So these are quite long beams would be a shame just to throw them out!
Here's a picture
    42.2 KB
I'm guessing it might be glued and doweled? Unless you can see any wood plugs hiding screws. If you are doing something else with it I guess just cutting them off the handrail is the way forward.
It doesn't look like the normal way of doing it with the uprights sitting in a rebate and having pieces of wood to lock them in.
Unless it's the perspective but it also seems to be a good job you are replacing it as the uprights look too far apart for modern regs (at least in the UK)
As for what to do with it, do you need a load of oversized pepper mills? could probably make a few candle sticks, either re-turning them if you have a lathe or just cutting them off at appropriate places. Coffee table legs? Fancy porch swing with nice corner pieces?
If I’m correct in assuming that you have the whole thing in one piece, two stringers with the steps/treads between?
If that’s the case then after dismantling the balustrade which as @Agent_zed says is normally a groove running up the underside of the handrail with the individual balusters between small slips of wood.
Then turn the whole stair part over and the treads and risers will be seen, these are set in housings in the stringers with wedges holding it all tight, (sorry I don’t know your ability level) this does mean unfortunately that the two largest pieces of wood are not very useful without proper equipment.
On an old staircase the treads and risers will be solid wood, Oak? as you say. These might be more useful for you to make things from.
Ian
Thanks guys for your replies.
@Cabinetman that's a bit technical language, I just started working on wood a few months ago and learned a great deal on this forum but still have a lot to learn.
So essentially I have to start hammering the handrail away from the balusters and hopefully they are not glued. If they are glues I have to saw them off.
Here's a more complete picture, sorry for quality
    81.1 KB
